Сб фев 09, 2019 20:48:09
This program was created by the
CodeWizardAVR V3.12 Advanced
Automatic Program Generator
© Copyright 1998-2014 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 03.02.2019
Author :
Company :
Comments:
Chip type : ATmega8A
Program type : Application
AVR Core Clock frequency: 8,000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega8.h>
#include <delay.h>
// Declare your global variables here
unsigned long int k;
// SPI functions
#include <spi.h>
#define CS1 PORTD |= (1<<5) //
#define CS0 PORTD &= ~(1<<5) //
#define RESET1 PORTD |= (1<<6) //
#define RESET0 PORTD &= ~(1<<6) //
#define DC1 PORTD |= (1<<7) //
#define DC0 PORTD &= ~(1<<7) //
void Wr_comm (volatile unsigned char comm) //функция записи команды
DC0;
spi(comm);
//while(!(SPSR & (1<<SPIF)));
DC1;
void Wr_param (volatile unsigned char param) //функция записи параметра
spi(param);
void Wr_data (volatile unsigned int data) //функция записи параметра
spi(data>>8);
spi(data);
void Init_ili (void) //функция инициализации
RESET0;
delay_us(15); //15микросекунд
RESET1;
CS0;
delay_ms(120);
Wr_comm(0x01);
delay_ms(120);
Wr_comm(0x3A); //установка 16 бит цвета Pixel Format Set или COLMOD
Wr_param(0x55); //установка 16 бит
Wr_comm(0x11); //Sleep OUT (код – 0x11)выводит ILI9341 из состояния сна
delay_ms(130); //120милисекунд
Wr_comm(0x29); //Display ON (код – 0x29) – подключение дисплея к ОЗУ
delay_ms(130);
Wr_comm(0x2C);
for (k=0;k<76800;k++)
Wr_data(0x07E0);
CS1;
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Function: Bit7=In Bit6=In Bit5=Out Bit4=In Bit3=Out Bit2=Out Bit1=In Bit0=In
DDRB=(0<<DDB7) | (0<<DDB6) | (1<<DDB5) | (0<<DDB4) | (1<<DDB3) | (1<<DDB2) | (0<<DDB1) | (0<<DDB0);
// State: Bit7=T Bit6=T Bit5=0 Bit4=T Bit3=0 Bit2=0 Bit1=T Bit0=T
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Port C initialization
// Function: Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRC=(0<<DDC6) | (0<<DDC5) | (0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0);
// State: Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTC=(0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0);
// Port D initialization
// Function: Bit7=Out Bit6=Out Bit5=Out Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRD=(1<<DDD7) | (1<<DDD6) | (1<<DDD5) | (0<<DDD4) | (0<<DDD3) | (0<<DDD2) | (0<<DDD1) | (0<<DDD0);
// State: Bit7=0 Bit6=0 Bit5=0 Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=(0<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Disconnected
// OC1B output: Disconnected
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10);
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0<<AS2;
TCCR2=(0<<PWM2) | (0<<COM21) | (0<<COM20) | (0<<CTC2) | (0<<CS22) | (0<<CS21) | (0<<CS20);
TCNT2=0x00;
OCR2=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=(0<<OCIE2) | (0<<TOIE2) | (0<<TICIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (0<<TOIE1) | (0<<TOIE0);
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (0<<ISC00);
// USART initialization
// USART disabled
UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (0<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8);
// Analog Comparator initialization
// Analog Comparator: Off
// The Analog Comparator's positive input is
// connected to the AIN0 pin
// The Analog Comparator's negative input is
// connected to the AIN1 pin
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
SFIOR=(0<<ACME);
// ADC initialization
// ADC disabled
ADCSRA=(0<<ADEN) | (0<<ADSC) | (0<<ADFR) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0);
// SPI initialization
// SPI Type: Master
// SPI Clock Rate: 125,000 kHz
// SPI Clock Phase: Cycle Start
// SPI Clock Polarity: Low
// SPI Data Order: MSB First
SPCR=(0<<SPIE) | (1<<SPE) | (0<<DORD) | (1<<MSTR) | (0<<CPOL) | (0<<CPHA) | (1<<SPR1) | (0<<SPR0);
SPSR=(0<<SPI2X);
// TWI initialization
// TWI disabled
TWCR=(0<<TWEA) | (0<<TWSTA) | (0<<TWSTO) | (0<<TWEN) | (0<<TWIE);
RESET1;CS1;DC1;
delay_ms(300);
Init_ili();
while (1)
// Place your code here
Сб фев 09, 2019 22:06:58
// отправка 2 байт в дисплей по SPI
void sendWordILI9341(unsigned int wordToSend) {
SPDR = wordToSend >> 8;
while((SPSR & (1<<SPIF)) == 0);
SPDR = wordToSend & 0xFF;
Вс фев 10, 2019 13:03:04
Вс фев 10, 2019 15:27:15
broocks писал(а):8 LED 470 ом +3,3V
Вс фев 10, 2019 17:51:40
Вс фев 10, 2019 18:29:44
Пн фев 11, 2019 18:05:33
Пн фев 11, 2019 18:18:36
Пн фев 11, 2019 18:35:51
Пн фев 11, 2019 19:06:13
Пн фев 11, 2019 19:47:32
Пн фев 11, 2019 20:09:05
Пн фев 11, 2019 20:35:58
Пн фев 11, 2019 21:07:47
Пн фев 11, 2019 21:25:01
Библиотека умеет выводить текст в разных направлениях и с возможностью отзеркаливания по двум координатам.
По линиям - если вы внимательно смотрели код, то там горизонтальные и вертикальные линии умеют так же рисоваться в потоковом режиме - смотрите дефайн DISPLAY_USE_AREA.
И да, человек попросил исходники - он их получил.
Пн фев 11, 2019 21:41:31
Пн фев 11, 2019 21:56:51
И да, вы можете предложить топикстартеру свою библитоеку на 5 дисплеев. Я не претендую на истину в последней инстанции....
Пн фев 11, 2019 21:57:13
Reflector писал(а):Все цветные дисплеи однотипные, там можно задавать направление отрисовки по любой оси, собственно потому один и то же код и может работать при разной ориентации экрана. Другими словами если в обычном режиме отрисовка идет слева направо и сверху вниз, то настроив ее так чтобы выводило справа налево можно так же быстро нарисовать отзеркаленый символ. Хотя если учесть насколько редко такой вывод в принципе нужен, можно спокойно делать быструю обычную функцию и медленную специальную, по крайней мере на твоих скринах часов я ни одного повернутого или отзеркаленного символа не вижу...
Пн фев 11, 2019 21:59:20
Пн фев 11, 2019 23:16:24
broocks писал(а):часы и управление температурой теплых полов во всей квартире, связь по nRF24L01 5 абонентов, датчик температуру по I2
