Сб мар 02, 2019 07:09:02
К какой памяти ?ПростоНуб писал(а):доступа к памяти
Сб мар 02, 2019 07:32:48
The bus matrix implements round-robin scheduling, thus ensuring at least half of the system bus bandwidth (both to memory and peripheral) for the CPU.
Сб мар 02, 2019 07:50:19
Сб мар 02, 2019 10:05:20
Сб мар 02, 2019 10:14:03
Хм.. Интересно...Reflector писал(а):на F4 DMA может читать по 32 бита и два раза писать по 16, это должно меньше загружать шину.
Сб мар 02, 2019 10:21:38
Сб мар 02, 2019 10:31:55
Сб мар 02, 2019 21:58:10
static DMA_InitTypeDef dma;
static __IO int32_t dma_cnt;
static __IO uint8_t * p_dist;
static __IO uint8_t * p_sourse;
static __IO uint8_t inc_dist=0;
static __IO uint8_t inc_sourse=0;
void dma_m2m_init(){
RCC->AHB1ENR |= RCC_AHB1Periph_DMA2;
dma.DMA_Channel = DMA_Channel_0;
// dma.DMA_PeripheralBaseAddr = (uint32_t)lcd_buf;
// dma.DMA_Memory0BaseAddr = (uint32_t)FMC_DATA_ADDRR;
dma.DMA_DIR = DMA_DIR_MemoryToMemory;
// dma.DMA_BufferSize = (size);
dma.DMA_PeripheralInc = DMA_PeripheralInc_Enable;
dma.DMA_MemoryInc = DMA_MemoryInc_Disable;
dma.DMA_PeripheralDataSize = DMA_MemoryDataSize_HalfWord;
dma.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
dma.DMA_Mode = DMA_Mode_Normal;
dma.DMA_Priority = DMA_Priority_VeryHigh; // DMA_Priority_Low;
dma.DMA_FIFOMode = DMA_FIFOMode_Enable; // DMA_FIFOMode_Disable;
dma.DMA_FIFOThreshold = DMA_FIFOThreshold_Full; // DMA_FIFOThreshold_1QuarterFull;
dma.DMA_MemoryBurst = DMA_MemoryBurst_Single;
dma.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream0, &dma);
NVIC_EnableIRQ(DMA2_Stream0_IRQn);
DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, ENABLE);
void DMA2_Stream0_IRQHandler(void){
if (DMA_GetITStatus(DMA2_Stream0, DMA_IT_TCIF0) == SET){
DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TCIF0);
DMA_Out();
static void DMA_Out(){
static uint32_t dma_size_out=0;
if(dma_cnt<=0){
DMA_End();
return;
if(dma_cnt<=50000) dma_size_out = dma_cnt;
else dma_size_out = 50000;
dma_cnt -= dma_size_out;
DMA2_Stream0->M0AR =(__IO uint32_t)p_sourse ;
DMA2_Stream0->PAR =(__IO uint32_t)p_dist ;
DMA2_Stream0->NDTR = dma_size_out;
DMA2_Stream0->CR |= DMA_SxCR_EN;
if(inc_dist) p_dist+=dma_size_out;
if(inc_sourse) p_sourse+=dma_size_out;
void dma_m2m_send(void *dist, uint8_t dist_inc, void *sourse, uint8_t sourse_inc, uint32_t size){
p_dist = (uint8_t*)dist;
p_sourse = (uint8_t*)sourse;
dma_cnt = size;
inc_dist = dist_inc;
if(dist_inc) DMA2_Stream0->CR |= DMA_SxCR_PINC;
else DMA2_Stream0->CR &= ~DMA_SxCR_PINC;
inc_sourse = sourse_inc;
if(sourse_inc) DMA2_Stream0->CR |= DMA_SxCR_MINC;
else DMA2_Stream0->CR &= ~DMA_SxCR_MINC;
DMA_Out();
void SDRAM_Init(void)
FMC_SDRAMInitTypeDef FMC_SDRAMInitStructure;
FMC_SDRAMTimingInitTypeDef FMC_SDRAMTimingInitStructure;
/* GPIO configuration for FMC SDRAM bank */
SDRAM_GPIOConfig();
/* Enable FMC clock */
RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FMC, ENABLE);
/* FMC Configuration ----------*/
/* FMC SDRAM Bank configuration */
/* Timing configuration for 90 Mhz of SD clock frequency (180Mhz/2) */
/* TMRD: 2 Clock cycles */
FMC_SDRAMTimingInitStructure.FMC_LoadToActiveDelay = 2; //2;
/* TXSR: min=70ns (7x11.11ns) */
FMC_SDRAMTimingInitStructure.FMC_ExitSelfRefreshDelay = 7; //7;
/* TRAS: min=42ns (4x11.11ns) max=120k (ns) */
FMC_SDRAMTimingInitStructure.FMC_SelfRefreshTime = 4;
/* TRC: min=70 (7x11.11ns) */
FMC_SDRAMTimingInitStructure.FMC_RowCycleDelay = 7; // 7;
/* TWR: min=1+ 7ns (1+1x11.11ns) */
FMC_SDRAMTimingInitStructure.FMC_WriteRecoveryTime = 2; // 2;
/* TRP: 20ns => 2x11.11ns */
FMC_SDRAMTimingInitStructure.FMC_RPDelay = 2; // 2;
/* TRCD: 20ns => 2x11.11ns */
FMC_SDRAMTimingInitStructure.FMC_RCDDelay = 2; // 2;
/* FMC SDRAM control configuration */
FMC_SDRAMInitStructure.FMC_Bank = FMC_Bank2_SDRAM;
/* Row addressing: [7:0] */
FMC_SDRAMInitStructure.FMC_ColumnBitsNumber = FMC_ColumnBits_Number_8b;
/* Column addressing: [11:0] */
FMC_SDRAMInitStructure.FMC_RowBitsNumber = FMC_RowBits_Number_12b;
FMC_SDRAMInitStructure.FMC_SDMemoryDataWidth = SDRAM_MEMORY_WIDTH;
FMC_SDRAMInitStructure.FMC_InternalBankNumber = FMC_InternalBank_Number_4;
FMC_SDRAMInitStructure.FMC_CASLatency = SDRAM_CAS_LATENCY;
FMC_SDRAMInitStructure.FMC_WriteProtection = FMC_Write_Protection_Disable;
FMC_SDRAMInitStructure.FMC_SDClockPeriod = SDCLOCK_PERIOD;
FMC_SDRAMInitStructure.FMC_ReadBurst = FMC_Read_Burst_Enable;
FMC_SDRAMInitStructure.FMC_ReadPipeDelay = FMC_ReadPipe_Delay_0;
FMC_SDRAMInitStructure.FMC_SDRAMTimingStruct = &FMC_SDRAMTimingInitStructure;
/* FMC SDRAM bank initialization */
FMC_SDRAMInit(&FMC_SDRAMInitStructure);
/* FMC SDRAM device initialization sequence */
SDRAM_InitSequence();
static uint16_t SDRAM buf_sdram[384000];
void Main_Task(void *pvParameters) {
OS_Delay(100 Ms);
LCD_SetArea(0,0,799,479);
uint16_t rgb = RGB565CONVERT(200, 100, 100);
while(1){
OS_Delay(100 Ms);
GPIO_SetBits(GPIOG, GPIO_Pin_14);
//dma_m2m_send(rgb, 0, buf_sdram, 1, 384000*2);
//wait_dma();
for(uint32_t i=0; i<384000;i++) buf_sdram[i]=rgb;
GPIO_ResetBits(GPIOG, GPIO_Pin_14);
GPIO_SetBits(GPIOG, GPIO_Pin_13);
LCD_MemStart();
//dma_m2m_send(buf_sdram, 1, (void*)0x60020000, 0, sizeof(buf_sdram));
//wait_dma();
for(uint32_t i=0; i<384000;i++) *(uint16_t*)0x60020000 = buf_sdram[i];
GPIO_ResetBits(GPIOG, GPIO_Pin_13);
dma.DMA_MemoryBurst = DMA_MemoryBurst_INC8; //DMA_MemoryBurst_Single ;
dma.DMA_PeripheralBurst = DMA_PeripheralBurst_INC8; // DMA_PeripheralBurst_Single;
Пн мар 04, 2019 12:53:47
