Чт май 16, 2013 11:18:16
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.all;
USE IEEE.STD_LOGIC_ARITH.all;
USE IEEE.STD_LOGIC_UNSIGNED.all;
ENTITY key IS
PORT( keyboard_clk, keyboard_data, clock_25Mhz ,
reset, read : IN STD_LOGIC;
scan_code : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
scan_ready : OUT STD_LOGIC);
END key;
ARCHITECTURE a OF key IS
SIGNAL INCNT : STD_LOGIC_VECTOR(3 downto 0);
SIGNAL SHIFTIN : STD_LOGIC_VECTOR(8 downto 0);
SIGNAL READ_CHAR : STD_LOGIC;
SIGNAL INFLAG, ready_set : STD_LOGIC;
SIGNAL keyboard_clk_filtered : STD_LOGIC;
SIGNAL filter : STD_LOGIC_VECTOR(7 downto 0);
SIGNAL lower_code_buf : STD_LOGIC_VECTOR(3 downto 0);
SIGNAL high_code_buf : STD_LOGIC_VECTOR(3 downto 0);
BEGIN
PROCESS (read, ready_set)
BEGIN
IF read = '1' THEN scan_ready <= '0';
ELSIF ready_set'EVENT and ready_set = '1' THEN
scan_ready <= '1';
END IF;
END PROCESS;
--This process filters the raw clock signal coming from the keyboard using a shift register and two AND gates
Clock_filter: PROCESS
BEGIN
WAIT UNTIL clock_25Mhz'EVENT AND clock_25Mhz= '1';
filter (6 DOWNTO 0) <= filter(7 DOWNTO 1) ;
filter(7) <= keyboard_clk;
IF filter = "11111111" THEN -- If 0hFF set keyboard_clk_filtered
keyboard_clk_filtered <= '1';
ELSIF filter= "00000000" THEN
keyboard_clk_filtered <= '0';
END IF;
END PROCESS Clock_filter;
--This process reads in serial data coming from the terminal
PROCESS
BEGIN
WAIT UNTIL (KEYBOARD_CLK_filtered'EVENT AND KEYBOARD_CLK_filtered='1');
IF RESET='1' THEN
INCNT <= "0000";
READ_CHAR <= '0';
ELSE
IF KEYBOARD_DATA='0' AND READ_CHAR='0' THEN
READ_CHAR<= '1';
ready_set<= '0';
ELSE
-- Shift in next 8 data bits to assemble a scan code
IF READ_CHAR = '1' THEN
IF INCNT < "1001" THEN -- If less than 9-bits keep shifting in data from keyboard
INCNT <= INCNT + 1;
SHIFTIN(7 DOWNTO 0) <= SHIFTIN(8 DOWNTO 1);
SHIFTIN(8) <= KEYBOARD_DATA;
ready_set <= '0';
-- End of scan code character, so set flags and exit loop
ELSE
scan_code <= SHIFTIN(7 DOWNTO 0);
READ_CHAR <='0';
ready_set <= '1';
INCNT <= "0000";
END IF;
END IF;
END IF;
END IF;
END PROCESS;
END a;
Чт май 16, 2013 22:57:02
ketron писал(а):как теперь это можно эмулировать в тестбенче?
ENTITY key_test IS
PORT(
END key_test;
Architecture test of key_test is
signal keyboard_clk, keyboard_data, clock_25Mhz , reset, read: STD_LOGIC:='0';
Component key IS
END component;
Begin
D: key
PORT MAP(
keyboard_clk=>keyboard_clk,
keyboard_data=>keyboard_data,
clock_25Mhz =>clock_25Mhz,
reset=>reset,
read=>read,
scan_code=>scan_code,
scan_ready=>scan_ready
--Тут должны быть процессы, соответствующие входным сигналам!
end test;
