Вот мой измененный RCdecoder.c
#include "globals.h"
#include "PICUSB.h"
extern BYTE cdc_In_buffer[64];
extern BDentry *Inbdp;
#pragma udata access uaccess
struct _rcStates
enum _state{
START=0,
WAIT,
IDLE,
CAPTURE,
DECODE,
SEND
}state;
}volatile near rcStates;
volatile near unsigned char count;
near char val;
near unsigned char byteno;
near unsigned char bitno;
near unsigned char i;
near unsigned char ticks;
near unsigned char signalLength;
near unsigned char irCode[6];
//disable timers, setup IR activity interrupt
void SetupRC5(void) {
rcStates.state=START;
//IRman protocol: respond to IR with OK...
//IR signals are first captured in the interrupt loop below
//when the capture is complete, the bits are decoded into bytes and sent to USB from this function
void ProcessIR(void) {
//wait for line to be clear
if(rcStates.state==START)
if (IRX == 1)
rcStates.state=WAIT;
//start timer, wait for 5.5ms
T2_5440us();
T2IF=0;
T2IE=1;
T2ON=1;
//arm interrupt
IRRXIF=0;
IRRX_EDGE=0;
IRRXIE=1;
//signal to main loop that executing a sleep instruction
// will not harm
return(2);
else if(rcStates.state==DECODE)
// 1 tick = 61us
if (count == 67)
//lead pulse
if ((irToy.s[0] > 133) && (irToy.s[0] < 162) &&
(irToy.s[1] > 65) && (irToy.s[1] < 81))
for (i=0; i<6; i++)
irCode[i] = 0;
irCode[0] = 'N';
byteno = 1;
bitno = 1;
for (i=0; i<32; i++)
//560 = 9ticks, 1680 = 27 ticks
val = irToy.s[2*i+3] + irToy.s[2*i+2];
// set bit "1"
if (val > 24)
irCode[byteno] |= bitno;
bitno <<= 1;
if (bitno == 0)
byteno++;
bitno = 1;
} // end for
// NEC format error check
if (irCode[3] == ~(irCode[4]))
irCode[4] = 0;
rcStates.state = SEND;
else
irCode[0] = 'N';
irCode[1] = 'E';
irCode[2] = 1;
} // end if lead pulse
else
irCode[0] = 'd';
irCode[1] = 'a';
irCode[2] = 2;
irCode[3] = irToy.s[0];
irCode[4] = irToy.s[1];
irCode[5] = count;
}// end if count
// check for NEC repreat code
else if (count == 3)
//lead pulse for repeat 9ms, 2.25, 0.55
(irToy.s[1] > 30) && (irToy.s[1] < 45) &&
(irToy.s[2] > 4) && (irToy.s[2] <15))
// resend last code
else
irCode[0] = 'N';
irCode[1] = 'E';
irCode[2] = 4;
irCode[3] = count;
else
irCode[0] = 'N';
irCode[1] = 'E';
irCode[2] = 3;
irCode[3] = count;
//rcStates.events |= EV_ERROR;
}// DECODE
else if(rcStates.state==SEND)
if (getInReady())
for (i=0; i<6; i++)
cdc_In_buffer[i] = irCode[i];
putUnsignedCharArrayUsbUsart(cdc_In_buffer,6);
rcStates.state = START;
else
return(0);
//high priority interrupt routine
#pragma code INTERRUPTS
//#pragma interrupt IRdecoderInterruptHandlerHigh
void IRdecoderInterruptHandlerHigh(void) {
// signal change detected
if(IRRXIF == 1)
//busy, try again
if(rcStates.state==WAIT)
T2IE=0;
IRRXIE=0;
// first falling edge
else if(rcStates.state==IDLE)
// store length of signals in array
// 1 tick approx 61 us
T3_sample();
TMR3L=0;
T3ON=1;
count = 0;
rcStates.state=CAPTURE;
IRRX_EDGE ^= 1;
else if(rcStates.state==CAPTURE)
irToy.s[count] = TMR3L;
TMR3L=0;
// set timer to detect end of signal
//start timer 5ms
if (count==0)
T2_5440us();
T2IF=0;
T2IE=1;
T2ON=1;
count++;
if (count>=SAMPLE_ARRAY_SIZE)
rcStates.state=DECODE;
T2ON=0;
T3ON=0;
IRRXIE=0;
T2IE=0;
TMR2=0;
IRRX_EDGE ^= 1;
IRRXIF=0;
if (T2IF == 1)
//ready for receive
T2ON=0;
T2IE=0;
rcStates.state=IDLE;
//arm interrupt
IRRXIF=0;
IRRX_EDGE=0;
IRRXIE=1;
//end of signal
else if (rcStates.state==CAPTURE)
T2ON=0;
T3ON=0;
IRRXIE=0;
T2IE=0;
T2IF=0;
//#endif //RC_DECODERи HardwareProfile.h
#ifndef HARDWARE_PROFILE_H
#define HARDWARE_PROFILE_H
#define FIRMWARE_VERSION_H '2'
#define FIRMWARE_VERSION_L '2'
#define SAMPLE_ARRAY_SIZE 0x0080 //0x0010 JTR3 these are not used for SUMP mode. See sump.h and sump.c
#define SAMPLE_SIZE 0x0400 //0x0080 //(SAMPLE_ARRAY_SIZE*0x0008)
struct _irtoy {
unsigned char s[SAMPLE_ARRAY_SIZE];
//JTR2 this appears not to be used:
//unsigned char usbIn[30];
//unsigned char usbOut[64];
unsigned char HardwareVersion;
// unsigned char CrtlByte;
//hardware platform?
#define USBIRTOY //Dangerous Prototypes IR Toy, RX on RB4 and RB2,TX on RC2, 2550
#define IRRX_ONRB4 //force RB4 interrupt instead of INT2 on USBIRTOY
//#define HAD_USBIRC //hackaday RX on B4 only, PIC 2455
//select the correct interrupt pin depending on hardware and settings
#if defined (HAD_USBIRC) || defined (IRRX_ONRB4)// irRX B4 (25)
#define IRRX_LAT LATB
#define IRRX_TRIS TRISB
#define IRRX_PORT PORTB
#define IRX PORTBbits.RB4
#define IRRX_PIN 0b10000
#define IRRAW_PIN 0b10 //JTR3
#define IRRAW PORTBbits.RB1 // JTR3
#define IRRXIE INTCONbits.RBIE
#define IRRXIF INTCONbits.RBIF
#define IRRX_EDGE INTCON2bits.INTEDG2
#define T0_IP INTCON2bits.TMR0IP
#define T1_IP IPR1bits.TMR1IP
#define T2_IP IPR1bits.TMR2IP
#define T3_IP IPR2bits.TMR3IP
#define IRRX_IP INTCON2bits.RBIP
#define IRRAWINT1_IP INTCON3bits.INT1IP
#define CCP1_IP IPR1bits.CCP1IP
#else //use INT2 with edge trigger, schmidt buffer
#define IRRX_ONINT2 //tells other functions we're using INT2 interrupt
#define IRX PORTBbits.RB2
#define IRRXIE INTCON3bits.INT2IE
#define IRRXIF INTCON3bits.INT2IF
#define IRRX_IP INTCON3bits.INT2IP
#endif
#define IRRX_PULLUP INTCON2bits.RBPU //one pullup bit for all PORTB pins
#define EnableIRTOY_HI_IP() RCONbits.IPEN = 1
// LED C2 (13)
#define LED_LAT LATC
#define LED_TRIS TRISC
#define LED_PIN 0b100
#elif defined (USBIRTOY)
// LED A0 (2)
#define LED_LAT LATA
#define LED_TRIS TRISA
#define LED_PIN 0b1
#endif
// irTX C2 (13) CCP1
#define IRTX_LAT LATC
#define IRTX_TRIS TRISC
#define IRTX_PIN 0b100
//V2 extra hardware
//raw receiver
//CCP pin (12/RC1)
#define IRFREQ_CAP_LAT LATC
#define IRFREQ_CAP_TRIS TRISC
#define IRFREQ_CAP_PORT PORTC
#define IRFREQ_CAP_PIN 0b10
#define IRFREQ_CAP PORTCbits.RC1
#define IRFREQ_CAP_SETUP() PIE2bits.CCP2IE=0; T3CON=0; CCP2CON=0b00000101 //capture every rising edge (0100 = falling edge) //select timer1 for CPP2 in T3CON
#define IRFREQ_CAPIE PIE2bits.CCP2IE
#define IRFREQ_CAPIF PIR2bits.CCP2IF
#define IRFREQ_CAP_L CCPR2L
#define IRFREQ_CAP_H CCPR2H
#define IRFREQ_CCPxCON CCP2CON
//Interrupt pin (22/RB1)
#define IRFREQ_INT_LAT LATB
#define IRFREQ_INT_TRIS TRISB
#define IRFREQ_INT_PORT PORTB
#define IRFREQ_INT_PIN 0b10
#define IRFREQ_INT PORTBbits.RB1
//T1/3 external clock (11/RC0)
#define IRFREQ_EC_LAT LATC
#define IRFREQ_EC_TRIS TRISC
#define IRFREQ_EC_PORT PORTC
#define IRFREQ_EC_PIN 0b1
#define IRFREQ_EC PORTCbits.RC0
//all connected IR FREQ pin to input
#define IRFREQ_PIN_SETUP() IRFREQ_CAP_TRIS|=IRFREQ_CAP_PIN; IRFREQ_INT_TRIS|=IRFREQ_INT_PIN; IRFREQ_EC_TRIS|=IRFREQ_EC_PIN
// RX C7 (18)
// TX C6 (17)
#if 0
#define dLedOff() LED_LAT&=(~LED_PIN) // JTR redefine led for debugging
#define dLedOn() LED_LAT|=LED_PIN
#define dbLedToggle() LedOut(); LED_LAT ^=LED_PIN
#define LedOff()
#define LedOn()
#define LedToggle()
#else
#define dLedOff()
#define dLedOn()
#define LedOff() LED_LAT &=(~LED_PIN) //JTR TODO uncomment
#define LedOn() LED_LAT|=LED_PIN //JTR TODO uncomment
#define LedToggle() LED_LAT ^=LED_PIN
#endif
#define LedOut() LED_TRIS&=(~LED_PIN)
#define LedIn() LED_TRIS|=LED_PIN
#define T0_IF INTCONbits.T0IF
#define T0_IE INTCONbits.T0IE
#define T0ON T0CONbits.TMR0ON
#define T1IF PIR1bits.TMR1IF
#define T1IE PIE1bits.TMR1IE
#define T1ON T1CONbits.TMR1ON
#define T2IF PIR1bits.TMR2IF
#define T2IE PIE1bits.TMR2IE
#define T2ON T2CONbits.TMR2ON
#define T3ON T3CONbits.TMR3ON
#define IRRAWINTIF INTCON3bits.INT1IF
#define IRRAWINTIE INTCON3bits.INT1IE
//10us timer for TVBGONE on TIMER1 (65415)
#define T1_10usOffset() TMR1H=0xFF; TMR1L=0x9A //87
//10khz default sampling clock for IRIO on TIMER1
#define T1_OFFSET 0xFB4B //64331 preload = 10006.8kHz
#define T1_OFFSETH 0xFB //(T1_OFFSET>>8)
#define T1_OFFSETL 0x4B //(T1_OFFSET &= (~0xff00))
#define T1_10kHzOffset() TMR1H=T1_OFFSETH; TMR1L=T1_OFFSETL
//SUMP sample period with TIMER2
#define T2_RXsampleperiod() PR2 = 150; T2CON = PRE_x4 + POST_x2 //10040.1Hz
//RC5 bit and half bit period with TIMER2
#define T2_RC5halfbitperiod() PR2=222; T2CON=PRE_x4+POST_x6 //setup to hit in the middle of next bit period
#define T2_RC5bitperiod() PR2=222; T2CON=PRE_x4+POST_x12 //full bit values from now on
#define T2_5440us() PR2=254; TMR2=0; T2CON=PRE_x16+POST_x16
#define T3_sample() T3CON=0b00010110
#define PWMon() TMR2=0;CCP1CON |=0b1100
#define PWMoff() CCP1CON &=(~0b1100)
//we don't use these, disable
#define self_power 1
#define USB_BUS_SENSE 1
#define BootloaderJump() _asm goto 0x16 _endasm
//TMR2 Pre- and post- scalers
#define PRE_x4 0b01
#define PRE_x16 0b11
#define POST_x2 0b1000
#define POST_x3 0b10000
#define POST_x4 0b11000
#define POST_x5 0b100000
#define POST_x6 0b101000
#define POST_x7 0b110000
#define POST_x8 0b111000
#define POST_x9 0b1000000
#define POST_x10 0b1001000
#define POST_x11 0b1010000
#define POST_x12 0b1011000
#define POST_x13 0b1100000
#define POST_x14 0b1101000
#define POST_x15 0b1110000
#define POST_x16 0b1111000
#endifПрошивки прикрепил ниже.
