[phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path Блок питания с electronics-lab - Страница 11 - Форум РадиоКот
обьясняю подключаю амперметр в разрыв лампочки потребление которой сотовляет 12 вольт 1 ампер на амперметре показано что лампочка жрёт ровно 1 ампер при вращении реостата P2 не чего не происходит только в конце когда загораеться лампочка короткого замыкания ток можно регулировать буквально крутиться 2мм и все
какое напряжение на выходе U1 (6 нога). А также проверьте номиналы R17,18,21 и P2 (проверьте линейный ли он, сопротивление должно меняться плавно. А не по резконарастающей или наоборот)
