Dali_esp.ino
#include "Dali.h"
const int DALI_TX = 4;
const int DALI_RX_A = A0;
void setup()
Serial.begin(115200);
dali.setupTransmit(DALI_TX);
dali.setupAnalogReceive(DALI_RX_A);
dali.busTest();
dali.msgMode = true;
void loop()
const int delaytime = 500;
String comMsg;
// Read command from port
delay(delaytime);
while (Serial.available())
comMsg = comMsg + (char)(Serial.read());
if (comMsg == "level")
dali.transmit(0b00000001, QUERY_ACTUAL_LEVEL);
Serial.println("Lamp 1 level:");
Serial.println(dali.receive());
delay(10);
dali.transmit(0b00000011, QUERY_ACTUAL_LEVEL);
Serial.println("Lamp 2 level:");
delay(10);
dali.transmit(0b00000101, QUERY_ACTUAL_LEVEL);
Serial.println("Lamp 3 level:");
delay(10);
};Спойлер
#ifndef dali_h
#define dali_h
//timer scaling factors for different transmission speeds
#define MAN_300 0
#define MAN_600 1
#define MAN_1200 2
#define MAN_2400 3
#define MAN_4800 4
#define MAN_9600 5
#define MAN_19200 6
#define MAN_38400 7
Timer 2 in the ATMega328 and Timer 1 in a ATtiny85 is used to find the time between
each transition coming from the demodulation circuit.
Their setup is for sampling the input in regular intervals.
For practical reasons we use power of 2 timer prescaller for sampling,
for best timing we use pulse lenght as integer multiple of sampling speed.
We chose to sample every 8 ticks, and pulse lenght of 48 ticks
thats 6 samples per pulse, lower sampling rate (3) will not work well for
innacurate clocks (like internal oscilator) higher sampling rate (12) will
cause too much overhead and will not work at higher transmission speeds.
This gives us 16000000Hz/48/256 = 1302 pulses per second (so it's not really 1200)
At different transmission speeds or on different microcontroller frequencies, clock prescaller is adjusted
to be compatible with those values. We allow about 50% clock speed difference both ways
allowing us to transmit even with up to 100% in clock speed difference
// DALI coomands
#define BROADCAST_DP 0b11111110
#define BROADCAST_C 0b11111111
#define ON_DP 0b11111110
#define OFF_DP 0b00000000
#define ON_C 0b00000101
#define OFF_C 0b00000000
#define QUERY_STATUS 0b10010000
#define QUERY_ACTUAL_LEVEL 0b10100000
#define RESET 0b00100000
//setup timing for transmitter
#define HALF_BIT_INTERVAL 1666
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#include <pins_arduino.h>
#endif
class Dali
public:
Dali(); //the constructor
void setTxPin(uint8_t pin); //set the arduino digital pin for transmit.
void setRxAnalogPin(uint8_t pin); //set the arduino digital pin for receive.
void workAround1MhzTinyCore(uint8_t a = 1); //apply workaround for defect in tiny Core library for 1Mhz
void setupTransmit(uint8_t pin); //set up transmission
void setupAnalogReceive(uint8_t pin);
void transmit(uint8_t cmd1, uint8_t cmd2); //transmit 16 bits of data
void scanShortAdd(); //scan for short address
void busTest(); // bus test
void initialisation(); //initialization of new luminaries
bool cmdCheck(String & input, int16_t & cmd1, int16_t & cmd2);
uint8_t receive(); //get response
int16_t minResponseLevel();
int16_t maxResponseLevel();
uint8_t speedFactor;
uint16_t delay1;
uint16_t delay2;
uint16_t period;
String errorMsg; //error message of last operation
bool msgMode; //0 - get only response from dali bus to COM; 1 - response with text (comments)
bool getResponse;
uint8_t RxAnalogPin;
long daliTimeout = 20000; //us, DALI response timeout
int16_t analogLevel = 870; //analog border level (less - "0"; more - "1")
private:
void sendByte(uint8_t b); //transmit 8 bits of data
void sendBit(int16_t b); //transmit 1 bit of data
void sendZero(void); //transmit "0"
void sendOne(void); //transmit "1"
void splitAdd(long input, uint8_t &highbyte, uint8_t &middlebyte, uint8_t &lowbyte); //split random address
int16_t readBinaryString(char *s);
uint8_t TxPin;
uint8_t applyWorkAround1Mhz;
uint8_t rxAnalogPin = 0;
};//end of class Dali
// Cant really do this as a real C++ class, since we need to have
// an ISR
extern "C"
extern Dali dali;
#endifСпойлер
#include "Dali.h"
Dali::Dali() //constructor
applyWorkAround1Mhz = 0;
void Dali::setTxPin(uint8_t pin)
TxPin = pin; // user sets the digital pin as output
pinMode(TxPin, OUTPUT);
digitalWrite(TxPin, HIGH);
void Dali::setRxAnalogPin(uint8_t pin)
RxAnalogPin = pin; // user sets the digital pin as output
void Dali::workAround1MhzTinyCore(uint8_t a)
applyWorkAround1Mhz = a;
void Dali::setupAnalogReceive(uint8_t pin)
setRxAnalogPin(pin); // user sets the analog pin as input
void Dali::setupTransmit(uint8_t pin)
setTxPin(pin);
speedFactor = 2;
//we don't use exact calculation of passed time spent outside of transmitter
//because of high ovehead associated with it, instead we use this
//emprirically determined values to compensate for the time loss
#if F_CPU == 1000000UL
uint16_t compensationFactor = 88; //must be divisible by 8 for workaround
#elif F_CPU == 8000000UL
uint16_t compensationFactor = 12;
#else //16000000Mhz
uint16_t compensationFactor = 4;
#endif
#if (F_CPU == 80000000UL) || (F_CPU == 160000000) // ESP8266 80MHz or 160 MHz
delay1 = delay2 = (HALF_BIT_INTERVAL >> speedFactor) - 2;
#else
delay1 = (HALF_BIT_INTERVAL >> speedFactor) - compensationFactor;
period = delay1 + delay2;
delay2 -= 22; //22+2 = 24 is divisible by 8
if (applyWorkAround1Mhz) { //definition of micro delay is broken for 1MHz speed in tiny cores as of now (May 2013)
//this is a workaround that will allow us to transmit on 1Mhz
//divide the wait time by 8
delay1 >>= 3;
delay2 >>= 3;
#endif
#endif
void Dali::transmit(uint8_t cmd1, uint8_t cmd2) // transmit commands to DALI bus (address byte, command byte)
sendBit(1);
sendByte(cmd1);
sendByte(cmd2);
void Dali::sendByte(uint8_t b)
for (int16_t i = 7; i >= 0; i--)
sendBit((b >> i) & 1);
void Dali::sendBit(int16_t b)
if (b) {
sendOne();
else {
sendZero();
void Dali::sendZero(void)
delayMicroseconds(delay2);
digitalWrite(TxPin, LOW);
delayMicroseconds(delay1);
void Dali::sendOne(void)
void Dali::busTest() //DALI bus test
int16_t maxLevel;
int16_t minLevel;
//Luminaries must turn on and turn off. If not, check connection.
delay(100);
dali.transmit(BROADCAST_C, OFF_C); //Broadcast ON
delay(500);
dali.transmit(BROADCAST_C, ON_C); //Broadcast OFF
delay(100);
//while (!Serial); // wait for serial port to connect. Needed for native USB port only
//Receive response from luminaries: max and min level
dali.transmit(BROADCAST_C, QUERY_STATUS);
maxLevel = dali.maxResponseLevel();
minLevel = dali.minResponseLevel();
dali.analogLevel = (int16_t)(maxLevel + minLevel) / 2;
void Dali::splitAdd(long input, uint8_t &highbyte, uint8_t &middlebyte, uint8_t &lowbyte)
highbyte = input >> 16;
middlebyte = input >> 8;
lowbyte = input;
// define min response level
int16_t Dali::minResponseLevel()
const uint8_t dalistep = 40; //us
uint16_t rxmin = 1024;
uint16_t dalidata;
long idalistep;
for (idalistep = 0; idalistep < dali.daliTimeout; idalistep = idalistep + dalistep) {
dalidata = analogRead(RxAnalogPin);
if (dalidata < rxmin) {
rxmin = dalidata;
delayMicroseconds(dalistep);
return rxmin;
// define max response level
int16_t Dali::maxResponseLevel()
uint16_t rxmax = 0;
uint16_t dalidata;
long idalistep;
dalidata = analogRead(dali.RxAnalogPin);
if (dalidata > rxmax) {
rxmax = dalidata;
return rxmax;
//scan for individual short address
void Dali::scanShortAdd()
const int16_t delayTime = 10;
const uint8_t start_ind_adress = 0;
const uint8_t finish_ind_adress = 127;
uint8_t add_byte;
uint8_t device_short_add;
uint8_t response;
dali.transmit(BROADCAST_C, OFF_C); // Broadcast Off
delay(delayTime);
if (dali.msgMode) {
Serial.println("Short addresses:");
for (device_short_add = start_ind_adress; device_short_add <= 63; device_short_add++) {
add_byte = 1 + (device_short_add << 1); // convert short address to address byte
dali.transmit(add_byte, 0xA1);
response = dali.receive();
if (dali.getResponse) {
dali.transmit(add_byte, ON_C); // switch on
delay(1000);
dali.transmit(add_byte, OFF_C); // switch off
delay(1000);
else {
response = 0;
if (dali.msgMode) {
Serial.print("BIN: ");
Serial.print(device_short_add, BIN);
Serial.print(" ");
Serial.print("DEC: ");
Serial.print(device_short_add, DEC);
Serial.print(" ");
Serial.print("HEX: ");
Serial.print(device_short_add, HEX);
Serial.print(" ");
Serial.print("Get response");
else {
Serial.print("No response");
Serial.println();
else {
Serial.println(255, BIN);
else {
Serial.println(0, BIN);
dali.transmit(BROADCAST_C, ON_C); // Broadcast On
Serial.println();
delay(delayTime);
int16_t Dali::readBinaryString(char *s)
int16_t result = 0;
while (*s) {
result <<= 1;
if (*s++ == '1') result |= 1;
return result;
bool Dali::cmdCheck(String & input, int16_t & cmd1, int16_t & cmd2)
bool test = true;
input.replace(" ", ""); // Delete spaces
if (input.length() != 16) {
test = false; //check if command contain 16bit
else {
for (int16_t i = 0; i <= input.length() - 1; i++) {
if ((int16_t)input.charAt(i) == 49 or (int16_t)input.charAt(i) == 48) {}
else {
test = false;
if (test) {
char * S1 = new char[input.substring(0, 8).length() + 1];
strcpy(S1,input.substring(0, 8).c_str());
cmd1 = readBinaryString(S1);
char * S2 = new char[input.substring(8, 16).length() + 1];
strcpy(S2,input.substring(0, 8).c_str());
cmd2 = readBinaryString(S2);
return test;
void Dali::initialisation() {
const int16_t delaytime = 10; //ms
long low_longadd = 0x000000;
long high_longadd = 0xFFFFFF;
long longadd = (long)(low_longadd + high_longadd) / 2;
uint8_t highbyte;
uint8_t middlebyte;
uint8_t lowbyte;
uint8_t short_add = 0;
uint8_t cmd2;
delay(delaytime);
dali.transmit(BROADCAST_C, RESET);
delay(delaytime);
delay(delaytime);
delay(delaytime);
dali.transmit(0b10100101, 0b00000000); //initialise
delay(delaytime);
delay(delaytime);
dali.transmit(0b10100111, 0b00000000); //randomise
delay(delaytime);
if (dali.msgMode) {
Serial.println("Searching fo long addresses:");
while (longadd <= 0xFFFFFF - 2 and short_add <= 64) {
while ((high_longadd - low_longadd) > 1) {
dali.splitAdd(longadd, highbyte, middlebyte, lowbyte); //divide 24bit adress into three 8bit adresses
delay(delaytime);
dali.transmit(0b10110001, highbyte); //search HB
delay(delaytime);
dali.transmit(0b10110011, middlebyte); //search MB
delay(delaytime);
dali.transmit(0b10110101, lowbyte); //search LB
delay(delaytime);
dali.transmit(0b10101001, 0b00000000); //compare
if (minResponseLevel() > dali.analogLevel)
low_longadd = longadd;
else
high_longadd = longadd;
longadd = (low_longadd + high_longadd) / 2; //center
if (dali.msgMode) {
Serial.print(longadd + 1, BIN);
Serial.print(" ");
Serial.print(longadd + 1, DEC);
Serial.print(" ");
Serial.print(longadd + 1, HEX);
Serial.println();
else {
Serial.println(longadd + 1);
} // second while
if (high_longadd != 0xFFFFFF)
splitAdd(longadd + 1, highbyte, middlebyte, lowbyte);
delay(delaytime);
delay(delaytime);
delay(delaytime);
dali.transmit(0b10110111, 1 + (short_add << 1)); //program short adress
delay(delaytime);
dali.transmit(0b10101011, 0b00000000); //withdraw
delay(delaytime);
dali.transmit(1 + (short_add << 1), ON_C);
delay(1000);
dali.transmit(1 + (short_add << 1), OFF_C);
delay(delaytime);
short_add++;
if (dali.msgMode) {
Serial.println("Assigning a short address");
else {
if (dali.msgMode) {
Serial.println("End");
} // first while
dali.transmit(0b10100001, 0b00000000); //terminate
dali.transmit(BROADCAST_C, ON_C); //broadcast on
uint8_t Dali::receive() {
uint32_t startFuncTime = 0;
bool previousLogicLevel = 1;
bool currentLogicLevel = 1;
uint16_t arrLength = 20;
int16_t timeArray[arrLength];
int16_t i = 0;
int16_t k = 0;
bool logicLevelArray[arrLength];
//Serial.println("timeArray:");
//Serial.println(sizeof(timeArray[arrLength]));
int16_t response = 0;
dali.getResponse = false;
startFuncTime = micros();
// add check for micros overlap here!!!
while (micros() - startFuncTime < dali.daliTimeout and i < arrLength)
// geting response
if (analogRead(dali.RxAnalogPin) > dali.analogLevel) {
else {
currentLogicLevel = 0;
if (previousLogicLevel != currentLogicLevel) {
timeArray[i] = micros() - startFuncTime;
logicLevelArray[i] = currentLogicLevel;
previousLogicLevel = currentLogicLevel;
dali.getResponse = true;
i++;
arrLength = i;
//decoding to manchester
for (i = 0; i < arrLength - 1; i++)
if ((timeArray[i + 1] - timeArray[i]) > 0.75 * dali.period)
for (k = arrLength; k > i; k--)
timeArray[k] = timeArray[k - 1];
logicLevelArray[k] = logicLevelArray[k - 1];
//Serial.println(k);
arrLength++;
timeArray[i + 1] = (timeArray[i] + timeArray[i + 2]) / 2;
logicLevelArray[i + 1] = logicLevelArray[i];
k = 8;
for (i = 1; i < arrLength; i++) {
if (logicLevelArray[i] == 1) {
if ((int16_t)round((timeArray[i] - timeArray[0]) / (0.5 * dali.period)) & 1) {
response = response + (1 << k);
k--;
//remove start bit
response = (uint8_t)response;
return response;
Dali dali;
