[phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path [phpBB Debug] PHP Warning: in file [ROOT]/ext/nds/ads/event/listener.php on line 27: Undefined property: nds/ads/event/listener::$phpbb_root_path Никак не могу въехать в самые элементарные вопросы. - Страница 30 - Форум РадиоКот
добрый день всем ... появился у меня двигатель синхронный (сд 54 ) 60 оборотов ... хочу подключить к 220 .. но конденсаторов каких надо не имею имею только МБМ ( 250 в .025мкф... 500в 0.5 мкф...... (160в 0.5мкф-2штуки ), МРТ-221 1мкф 250в.... помогите пожалуйста запустить из того что есть
p-n-p от n-p-n можно отличить только по его наименованию (маркировке). Более мощные транзисторы, обычно, больше в размерах. Но и с одинаковыми размерами они могут довольно сильно отличаться по мощности. Поэтому и здесь нужно смотреть маркировку транзистора и искать параметры в справочниках (datasheet)
Мне 11 лет. (я учусь в 5 классе) Расскажите, пожалуйста, поподробней ещё раз этот закон Ома... не понял я его! Просто тут в Обучалке всё этот закон Ома... всё на нём.
[color=#4000FF][i]Мне 11 лет и я учусь в 5 классе.[/i][/color]
Коллекторные двигатели создают помехи для чего? Много раз видел как их шунтируют прямо на клеммах керамическим конденсатором, а включают через дроссели.
Соник писал(а):Коллекторные двигатели создают помехи для чего?
Для всего.Щётки искрят значит появляетса нестабильность(начанает плясать) питания(помеха),в зависмости от изменения кол-ва оборотов измяняетса и частота помехи,а дальше появляетса много гармоник которые могут и по радиочастоте напомеховать.
У кошки 4 ноги и хвост-плюс,минус,вход,выход,а хвост-земля.....Надо переходить с китайской бурды на канифоль.......[url=http://infobar.hsdn.org/][img]http://static.hsdn.org/infobar/350x60.gif[/img][/url]
Помехи от них распростроняются как по сети от которой они питаются, а также в окружающий радио эфир, так сказать. Включи пылесос в одну розетку с телевизором, увидиш как будет подергиваться изображение, да и на звуке то же. Или попробуй поднести к работающему двигателю приемник работающий на батарейках, то же услышиш помехи.
Соник писал(а):А какую ёмкость конденсатора припаять на его ножки, чтоб глушить шум?
Подбирай методом научного тыка(тебе надо добитса чтобы щётки не искрили,тогда и помех не будет),обычно от 0,1мкф до 1,5мкф применяют в пром.изделиях.
